Stu36 Posted September 15, 2022 Report Share Posted September 15, 2022 I’ve just rebuilt a sy250 engine and noticed the gear lever had a bit of play when clutch casing was fitted,I removed casing and it looks like the end of gear lever that fits onto the selector drum isn’t catching the selector properly,it’s moving up and down a fair bit,has anyone else encountered this?the gear lever is seated against the casing when pushed into position. Quote Link to comment Share on other sites More sharing options...
