madproffesor Posted February 27, 2006 Report Share Posted February 27, 2006 I have a ty250 pre pinky, with a leak on the gear selection shaft. Does anyone know the part number, I am in thailand and these numbers are hard to come by. Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted August 24, 2018 Report Share Posted August 24, 2018 I had two oil leaks on the left side. ONe was the clutch shaft seal which was leaking gear box oil and another was the left crank case seal behind the magneto plate. It was leaking pre-mix Mist and this was causing the points to corrode pretty fast and lose spark. I only have part number info for the TY 250 A's in 74 and 75 but if you need those numbers I can help you out. Quote Link to comment Share on other sites More sharing options...
