Ty250 Gear Box Oil Leak
madproffesor
  • 12 years later...
I had two oil leaks on the left side. ONe was the clutch shaft seal which was leaking gear box oil and another was the left crank case seal behind the magneto plate.  It was leaking pre-mix Mist and this was causing the points to corrode pretty fast and lose spark.
I only have part number info for the TY 250 A's in 74 and 75 but if you need those numbers I can help you out.
