Beetea Posted November 15, 2022 Report Share Posted November 15, 2022 Hello everybody, I hope for help here. I restored a TLM 200 2-stroke, replaced the missing carburetor with a Keihin PE24 from China (main jet 112, secondary jet 38, needle 2nd position from the top), spark plug NGK B6. I can't get it to run properly, with choke it revs way too high, without choke way too low and dies out. When trying to turn the idle gas higher, the engine suddenly ran at full speed and could not be stopped even by pulling off the spark plug connector... only after turning off the petrol and closing the exhaust pipe did the engine finally stop. Does anyone here know the original carburetor setup? Thanks in advance and greetings from Aachen, Germany Thomas Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted November 16, 2022 Report Share Posted November 16, 2022 I have no help other then: The TLM is a two-stroke. Make sure your carb is meant for a two-stroke and jetted subsequently. Happens I see those carbs jetted for 4-stroke pit bikes. And make sure it completely closes the throttle valve and have no air leaks or something that can screw things up. 1 1 Quote Link to comment Share on other sites More sharing options...
arnoux Posted November 17, 2022 Report Share Posted November 17, 2022 Keihin is a Japanese company, so if you have a Chinese "Keihin" I suspect you have a cheap knock off. 1 1 Quote Link to comment Share on other sites More sharing options...
Joshfdw Posted March 6, 2024 Report Share Posted March 6, 2024 When you restored your bike, did you manage to find a full gasket set for a rebuild Quote Link to comment Share on other sites More sharing options...
