robson Posted November 17, 2022 Report Share Posted November 17, 2022 Hi, my GasGas 300 came with disconnected throttle cable at the lever, any info how to connect it? Do I have to open the housing there? thanks Quote Link to comment Share on other sites More sharing options...
UG_ALLSTAR Posted November 17, 2022 Report Share Posted November 17, 2022 If it's a domino throttle then yes. Open the plastic housing via the hex bolts. Hook the ball into the throttle cam and reassemble. Don't overtighten, just snug. Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted November 18, 2022 Report Share Posted November 18, 2022 Make aure you test the cable after refitting it by turning the handlebars fully to right and left, engine not running. As you shut the throttle you should hear a click as the slide bottoms in the carburettor. If you don't hear this, you need to dial in a little slack on the cable with the adjuster on top of the carb. If the cable isn't bottoming properly the engine revs will race on start-up. Quote Link to comment Share on other sites More sharing options...
robson Posted November 18, 2022 Author Report Share Posted November 18, 2022 Below on the pics is the TB Domino housing what I'm asking about, is there a cover I can pop up or unscrew everything? Quote Link to comment Share on other sites More sharing options...
faussy Posted November 18, 2022 Report Share Posted November 18, 2022 No need to take the hex bolts out. Pull up on the tab just to the left of the d in 'domino'. 1 Quote Link to comment Share on other sites More sharing options...
robson Posted November 18, 2022 Author Report Share Posted November 18, 2022 On 11/18/2022 at 11:32 AM, faussy said: No need to take the hex bolts out. Pull up on the tab just to the left of the d in 'domino'. Expand are you sure i won't break it? Quote Link to comment Share on other sites More sharing options...
tony27 Posted November 19, 2022 Report Share Posted November 19, 2022 The cover is meant to just clip in place, close the throttle & fit the cable with the last piece to go in being the outer casing into the housing. Test that the cable is working properly before refitting the cover Quote Link to comment Share on other sites More sharing options...
