throttle cable install on GasGas
robson
Make aure you test the cable after refitting it by turning the handlebars fully to right and left, engine not running. As you shut the throttle you should hear a click as the slide bottoms in the carburettor. If you don't hear this, you need to dial in a little slack on the cable with the adjuster on top of the carb. If the cable isn't bottoming properly the engine revs will race on start-up.
The cover is meant to just clip in place, close the throttle & fit the cable with the last piece to go in being the outer casing into the housing. Test that the cable is working properly before refitting the cover
