SynchromeshBoulevard Posted November 25, 2022 Report Share Posted November 25, 2022 Hi, I am just finishing a Tiger cub trials project and would appreciate any advice on the rear sprocket. The current chain is a 520 and I see from the manuals and most postings that a 420 is the standard size. The 520 clears everything and I would like to stay with this if possible as it will be stronger and will cope with the awesome power of the 275cc upgrade on it...... Joking, the power is still not arm-wrenching but it does sound excellent! ;o) All the sprockets I can find on the interweb are 420, can anyone advise on where to go for a 520? Best Regards 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 25, 2022 Report Share Posted November 25, 2022 (edited) If you have access to machining, but a blank from ebay. They are available in a range of sizes. https://www.ebay.co.uk/itm/BLANK-REAR-SPROCKET-60T-520-CHAIN-SIZE-IN-7075-T6-DURAL-55mm-MACHINING-HOLE/165796871957?epid=6007943585&hash=item269a437f15:g:SBQAAOSwc2FZ8KYd&amdata=enc:AQAHAAAAoOiyUQ7pU23hZp4ktuWpuxbAxJEYKQ7UnW++bnNyV4QYxNsKW4TTtLnJ0UZ0Fu0gQm1hjlsOtSvHFEpQg9eRbLSDsMllGitdioZI3sw8pmZTxi7yT05XTb5+xlL95QPitXS8xEDzV2P/Ujd5zMBxcOFYAHPLceGJErRxXX4+vkNtlAMMWVNBzTLiQrwrNDap2jzV5d77B0y5UyUhEtwQCIE=|tkp:Bk9SR-a8nuaVYQ&pageci=b171333b-e727-4eba-a0b0-caebb2b8dfa9&redirect=mobile Edited November 25, 2022 by b40rt Quote Link to comment Share on other sites More sharing options...
SynchromeshBoulevard Posted November 25, 2022 Author Report Share Posted November 25, 2022 Hi b40rt, many thanks for the reply and advice, that is brilliant and opens up a world of stuff I had not thought about ! ;o) Best regards 1 Quote Link to comment Share on other sites More sharing options...
robido Posted November 25, 2022 Report Share Posted November 25, 2022 Feked.com have 520 for cub. C15 1 Quote Link to comment Share on other sites More sharing options...
SynchromeshBoulevard Posted November 27, 2022 Author Report Share Posted November 27, 2022 Hi Robido, thanks for the 'steer', I did try Feked previously but could not fine anything. I will try searching under C15 as that could be the difference ! Cheers Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted November 29, 2022 Report Share Posted November 29, 2022 Just a thought. Make sure you have a problem with the 420 chain before even think about a 520 replacement. My experience tells me the 420 chain i excellent in low to medium powered trials bikes (as most classic bikes are). The 520 chain is for the higher powered ones. The 420 means less polygon effect. That´s good. Quote Link to comment Share on other sites More sharing options...
