DRM Posted December 7, 2022 Report Share Posted December 7, 2022 I have a 2022 GasGas TXT Racing 300 and I am leaking air from the wheel lock on my front tire. I loosened the lock, cleaned it and re-inflated and it still leaks. Any suggestions? Quote Link to comment Share on other sites More sharing options...
kurtas Posted December 8, 2022 Report Share Posted December 8, 2022 Plumbers tape? Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 8, 2022 Report Share Posted December 8, 2022 Find the leak, patch it or replace the tube. 2 Quote Link to comment Share on other sites More sharing options...
fourex Posted December 8, 2022 Report Share Posted December 8, 2022 9 hours ago, DRM said: I have a 2022 GasGas TXT Racing 300 and I am leaking air from the wheel lock on my front tire. I loosened the lock, cleaned it and re-inflated and it still leaks. Any suggestions? You can't be serious with a question like that, surely? Quote Link to comment Share on other sites More sharing options...
Intotrials Posted December 8, 2022 Report Share Posted December 8, 2022 10 hours ago, DRM said: I have a 2022 GasGas TXT Racing 300 and I am leaking air from the wheel lock on my front tire. I loosened the lock, cleaned it and re-inflated and it still leaks. Any suggestions? The front tyre is not tubeless like the rear (hence the tyre lock). There will be a puncture in the tube, so you need to remove the tube then repair/replace it taking care when reinstalling that you don't pinch it as you lever the tyre back onto the rim. 1 Quote Link to comment Share on other sites More sharing options...
Intotrials Posted December 8, 2022 Report Share Posted December 8, 2022 23 minutes ago, fourex said: You can't be serious with a question like that, surely? It seems the poster assumes that the front is tubeless like the rear. 1 Quote Link to comment Share on other sites More sharing options...
fourex Posted December 8, 2022 Report Share Posted December 8, 2022 29 minutes ago, Intotrials said: It seems the poster assumes that the front is tubeless like the rear. Yes, It appears that way to me. DRM, pump your front tyre to something like 20 psi now, check it again in 24 hours. Figure it out from there. Simple like me. First time poster, we've probably been duped. 2 Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted December 16, 2022 Report Share Posted December 16, 2022 I would say, best is to get a new tube and replace. Use soap (or similar slippery) when fitting/removal the tyre. Use proper tyre tools. Not screwdrivers. Be careful not to puncture the tube. Lot of YouTube videos covering this. Quote Link to comment Share on other sites More sharing options...
Intotrials Posted December 16, 2022 Report Share Posted December 16, 2022 On 12/8/2022 at 9:22 AM, fourex said: First time poster, we've probably been duped No reply as yet, maybe you are right! Quote Link to comment Share on other sites More sharing options...
