dr nosh Posted December 14, 2022 Report Share Posted December 14, 2022 Last on here a lot when building a 248. Now that has gone, I am looking at a MH200, year 1983. (According to the VMCC dating cert for the V5). So, one key question. It has a plastic tank under the cover. What is the current position with modern, ethanol fuel with the plastic. Do you need to use a 'special' additive in the fuel? Does the tank have to be lined? Is there an alloy fuel tank from another Montesa that fits as a replacement? Quote Link to comment Share on other sites More sharing options...
woody Posted December 14, 2022 Report Share Posted December 14, 2022 The MH200 came with a plastic tank and seat unit, like the MH349, there was no cover with a tank underneath so it sounds as though someone has made a modification. It was the ealrier UK sold bikes with fibreglass tanks that had a seperate tank and cover The original MH tanks aren't affected by modern fuel. If the tank on yours is one of the pit bike type tanks, same as used under some TLR Honda tank covers they are fine with modern fuel Quote Link to comment Share on other sites More sharing options...
stpauls Posted December 15, 2022 Report Share Posted December 15, 2022 10 hours ago, woody said: The MH200 came with a plastic tank and seat unit, like the MH349, there was no cover with a tank underneath so it sounds as though someone has made a modification. It was the ealrier UK sold bikes with fibreglass tanks that had a seperate tank and cover The original MH tanks aren't affected by modern fuel. If the tank on yours is one of the pit bike type tanks, same as used under some TLR Honda tank covers they are fine with modern fuel ... "aren't affected by modern fuel" ... Brave comment! Quote Link to comment Share on other sites More sharing options...
dr nosh Posted December 15, 2022 Author Report Share Posted December 15, 2022 Also heard that kickstart gears are 'a known problem'. I was looking to buy this bike, but I'm cooling off a little....😐 Quote Link to comment Share on other sites More sharing options...
barnesy Posted December 16, 2022 Report Share Posted December 16, 2022 200's are great bikes, you will find it a lot more agile than your 248.. Kick start gear are more of an issue on 242s, I believe you can get replacement gears from inmotion 1 Quote Link to comment Share on other sites More sharing options...
