TonyT Posted December 18, 2022 Report Share Posted December 18, 2022 This maybe a stupid question, but how do you tell the difference between a 125/250 by looking at it? a gas gas txt pro for example with no stickers. Is there any obvious differences? Quote Link to comment Share on other sites More sharing options...
rotors7 Posted December 18, 2022 Report Share Posted December 18, 2022 I can't give you an answer on that, but I once bought a "240" JCM monopro from a well known dealer, got it home and stripped it, only to find an unusually large piston within. It was a 323, I wasn't too happy. So it's not a stupid question ! Quote Link to comment Share on other sites More sharing options...
mcman56 Posted December 20, 2022 Report Share Posted December 20, 2022 Some bikes have the engine size cast into the barrel. I think Sherco did that. The 2.9 was 270 or maybe 272. I have seen some Gas Gas cylinders with a 28 cast in. Is that 280 cc? Quote Link to comment Share on other sites More sharing options...
cascao Posted December 21, 2022 Report Share Posted December 21, 2022 Rear sprocket size will be a good start point Quote Link to comment Share on other sites More sharing options...
TonyT Posted December 21, 2022 Author Report Share Posted December 21, 2022 Yeah so I’ve recently found the engine has GG25 cast into it so I guess the 125s have different markings Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 24, 2022 Report Share Posted December 24, 2022 Pull the front header pipe, you should be able to get a rough measurement of the bore. Quote Link to comment Share on other sites More sharing options...
