lonewolf Posted December 29, 2022 Report Share Posted December 29, 2022 Hi looking at replacing my brake pads on my 2014 beta evo 250. Which ones are the best for general riding. Also which spark plugs are people using it has a bp7es currently in it which is not standard, will there be a reason for this. Quote Link to comment Share on other sites More sharing options...
MIckyT Posted December 30, 2022 Report Share Posted December 30, 2022 Red Galfer brake pads and BP5ES plug Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 30, 2022 Report Share Posted December 30, 2022 On 12/29/2022 at 9:03 AM, lonewolf said: . Also which spark plugs are people using it has a bp7es currently in it which is not standard, will there be a reason for this. Expand People sometimes mistakenly thing a 7 will run hotter than a 5, to reduce carbon build up. Quote Link to comment Share on other sites More sharing options...
richt Posted December 30, 2022 Report Share Posted December 30, 2022 (edited) Yeah, when they say a higher number is a hotter plug it's actually a cooler plug so that it can tolerate a hotter burn temperature as in higher performance engines. As for brake pads I use Red Galfer or DP. Edited December 30, 2022 by richt 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted December 31, 2022 Report Share Posted December 31, 2022 On 12/29/2022 at 9:03 AM, lonewolf said: Hi looking at replacing my brake pads on my 2014 beta evo 250. Which ones are the best for general riding. Also which spark plugs are people using it has a bp7es currently in it which is not standard, will there be a reason for this. Expand Two stroke trials bikes ridden in trials type riding go well with a 5 or 6 heat range plug (NGK heat range numbering). If the two stroke trials bike is used for sustained/continuous riding, like along a road or at the beach, or in desert sand, or trail riding that involves long climbs, a 7 or 8 heat range plug will work better. 1 Quote Link to comment Share on other sites More sharing options...
