trapezeartist Posted January 1, 2023 Report Share Posted January 1, 2023 The map indicator light has stopped working on my '21 ePure Race. It became erratic a little while ago but then recovered. Now it's completely dead. I've cleaned the connector contacts and smeared with dielectric grease, but no joy. Has anyone else had the problem? How did you fix it? Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted January 9, 2024 Author Report Share Posted January 9, 2024 This post had sunk so I forgot it and didn't update. I also have used a '22 command switch which I mounted upside-down. That puts the FRB button in a better place for my thumb, and I can live with the word 'map' being upside-down. I believe '23 switches are reversed from '22. I've also just fitted a Domino throttle. I advances the potentiometer 2 teeth to remove the dead motion but it is a little bit too tight now, so getting it spot-on is still a work in progress. Quote Link to comment Share on other sites More sharing options...
