TonyT Posted January 5, 2023 Report Share Posted January 5, 2023 Hi everyone, I've just changed the waterpump and seals on my txt pro and now I want to flush the milky oil out, what's the best product to use to flush it out so the cloudiness doesn't linger? Quote Link to comment Share on other sites More sharing options...
zippy Posted January 5, 2023 Report Share Posted January 5, 2023 Fill gear box with the same transmission fluid that you normally use. Run the bike, get everything warmed up, drain the gearbox right away, refill. repeat until the cloudiness (milkyness) is gone. 1 Quote Link to comment Share on other sites More sharing options...
cascao Posted January 8, 2023 Report Share Posted January 8, 2023 (edited) Cheap ATF oil. Change it after it get white or pink Edited January 8, 2023 by cascao Adding "cheap" word Quote Link to comment Share on other sites More sharing options...
