quiq Posted January 11, 2023 Report Share Posted January 11, 2023 Bonjour comment savoir si bielle d'une TXT 300 de 2012 est foutue...... Merci Quote Link to comment Share on other sites More sharing options...
turbofurball Posted January 11, 2023 Report Share Posted January 11, 2023 For anyone who doesn't speak french: On 1/11/2023 at 3:16 PM, quiq said: Hello, how can I tell if the conrod of a 2012 TXT 300 is screwed up? Thanks Expand Le moteur est-il encore en un seul morceau ou as-tu démonté le cylindre ? Si c'était moi, je retirerais simplement la tête et vérifierais les roulements de bielle, ils ne seront pas bons si c'est tordu ! (Is the engine still in once piece, or have you taken the cylinder off? If it were me I'd just remove the head and check the conrod bearings, they won't be good if it's bent!) Quote Link to comment Share on other sites More sharing options...
mcman56 Posted January 13, 2023 Report Share Posted January 13, 2023 A friend had a big end con rod failure on a 125 beta probably due to water getting in. When running it made a nasty grinding sound. When I pulled the cylinder I could feel up and down free movement of the rod. Quote Link to comment Share on other sites More sharing options...
