Montesa 4RT clutch issue
mil
Hi,
A long frustrating evening in the workshop!
I’ve just tried fitting dimpled steel clutch plates and although I worked pretty methodically through removal/ replacement with the manual the clutch lever now just doesn’t move at all and is locked out!
having read some other comments on here I managed to remove bolts with rattle gun and not clutch holding tool.
I checked the manual and realised it states to pull clutch lever in and keep it in as you remove the clutch cover (which I didn’t do).
I bled clutch lever then removed cover again, and lever pulls normally. But when refitted it goes stiff again!
Has anyone experienced this problem when changing a clutch on the 4rt?
thanks
Mil
Thank you! I had to have a few bites at the cherry but this was the issue and lined the dots up, and stacked the plates in the pressure plate and put all in the basket (as per manual) and it runs well now finally!
