Angelwing Posted January 31, 2023 Report Share Posted January 31, 2023 (edited) Hiya, I have a 1997 250 Scorpa with a weak intermittent spark. From what can gather the stator on these motors is a weak point. I'm getting readings of 200ohm between the white wire and earth and 789ohm between the red wire and earth, trouble is I don't know what the readings are supposed to be. Can some kind soul please tell me the correct readings? Thanks. Edited January 31, 2023 by Angelwing Quote Link to comment Share on other sites More sharing options...
Angelwing Posted February 19, 2023 Author Report Share Posted February 19, 2023 (edited) 521 views and not one single response? Wow! Trials folk were helpful back in the day. Anyroad, I sent the stator off to Westcountry Windings for testing, they passed it fit for service, so the readings I quoted are correct. The fault was in the high tension coil which I found on eBay courtesy of MXtrial, who responded to messages quickly and was very helpful, unlike the denizens of this forum. . . jd Edited February 19, 2023 by Angelwing 1 Quote Link to comment Share on other sites More sharing options...
trailmeisterjoe Posted February 19, 2023 Report Share Posted February 19, 2023 Well, you are asking about a 26 year old bike and the odds that someone else that HAS that same one AND knows the values you asked about are very, very low. Much newer and much more common one would have fairly quick answers. Sorry (and you probably don't want to hear this anyway). Joe Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 19, 2023 Report Share Posted February 19, 2023 On 2/19/2023 at 2:20 AM, Angelwing said: 521 views and not one single response? Wow! Trials folk were helpful back in the day. Anyroad, I sent the stator off to Westcountry Windings for testing, they passed it fit for service, so the readings I quoted are correct. The fault was in the high tension coil which I found on eBay courtesy of MXtrial, who responded to messages quickly and was very helpful, unlike the denizens of this forum. . . jd Expand 1 Quote Link to comment Share on other sites More sharing options...
