lonewolf Posted February 25, 2023 Report Share Posted February 25, 2023 Hi I'm wanting to repack my evo 250 silencer do you have to do the large box just after where header goes in or do you just do the straight part up before the plastic end cap Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted February 25, 2023 Report Share Posted February 25, 2023 (edited) Just do the straight bit. Beta sell a packing sheath to make the job really easy and guarantee the correct amount of packing. Make sure you burn off the metal pipe that runs through the silencer before you repack. I also burn off the whole exhaust whilst the silencer is off. I just pour petrol down it and let it burn off. Slow running trials engines have coked up exhausts. Don't burn off the alloy silencer though. I just soak that in a good degreaser overnight. The exhaust then polishes up again with some wire wool Brillo pad. The bike sounds crisp after the repack and burn off of exhaust. Edited February 25, 2023 by gazzaecowarrior Quote Link to comment Share on other sites More sharing options...
lonewolf Posted February 25, 2023 Author Report Share Posted February 25, 2023 I seen that you can get a preformed one but it looks like it does the large part too not just the end. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted February 25, 2023 Report Share Posted February 25, 2023 4 hours ago, lonewolf said: I seen that you can get a preformed one but it looks like it does the large part too not just the end. A lot of the packing is inside the end cap too. The steel metal pipe that terminates at the end of the rubber bung inside the end cap has holes in it. Just make sure the packing covers these holes. I put the preformed sheath over the steel tube, then slide the end of the tube into the rubber grommet in the end cap, then push the whole thing into the body of the silencer. I use a long screwdriver to make sure the packing doesn't get stuck when advancing it into the aluminium silencer body. Quote Link to comment Share on other sites More sharing options...
lonewolf Posted February 25, 2023 Author Report Share Posted February 25, 2023 With that preformed sheath stuff does it go down to the large box part. If it does how do you get the old stuff out. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted February 26, 2023 Report Share Posted February 26, 2023 (edited) The preformed sheath only goes on the aerated steel tube. Part of which is housed in the end cap and the rest in the upper body of the silencer. The aerated tube slots into a hole at either end. You can't put it anywhere else. The old packing should be wrapped around the aerated steel tube when you pull it out. It will be a black sooty mess. Any residual bits you can just pick out. I've added a photo. Packing goes on the highlighted blue but. Edited February 26, 2023 by gazzaecowarrior Quote Link to comment Share on other sites More sharing options...
lonewolf Posted February 26, 2023 Author Report Share Posted February 26, 2023 Ah I get it now. I thought looking at the shape of it from website shops it went all the way down into the box. Thanks for that. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted February 26, 2023 Report Share Posted February 26, 2023 Just put the packing on the tube first, then into the end cap, then advance into the silencer body. It's really tricky to do it the other way round because of the angled end cap. Your bike will feel like a new bike after. It makes a big difference. Quote Link to comment Share on other sites More sharing options...
