katoom400 Posted February 27, 2023 Report Share Posted February 27, 2023 Buddy just picked up a 2013 Evo 300 and we went riding for the first time yesterday. the front wheel is visibly offset to the left when looking at the front of the bike. However. the fender is in the middle between the fork legs but the wheel is well offset to the left. Is this normal? We did check to make sure the axle was tight and it was so I don't know how we could get the wheel centered as the rotor also seemed lined up in the caliper? Quote Link to comment Share on other sites More sharing options...
tshock250 Posted February 27, 2023 Report Share Posted February 27, 2023 Had this on a new Beta, the wheel had been built wrong & was some way off centre. Need to true the wheel to the correct offset. 1 Quote Link to comment Share on other sites More sharing options...
stpauls Posted February 27, 2023 Report Share Posted February 27, 2023 (edited) Never mind the bollocks. Before you do anything else at all: First SLACKEN OFF the clamp bolts on the triple trees (holding the fork tubes). Then loosen the fork brace/mudguard stay. Loosen off the wheel spindle nut too. Next twist the wheel, while holding on to the handlebars. Finally, when they look about right, retighten everything. Edited February 27, 2023 by stpauls 2 Quote Link to comment Share on other sites More sharing options...
faussy Posted February 28, 2023 Report Share Posted February 28, 2023 Both replies above are correct, depending on what you mean by offset, i.e. does the wheel point straight ahead but is closer to one fork leg than the other, or is the wheel in the centre of the fork legs but point of at a angle? Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted February 28, 2023 Report Share Posted February 28, 2023 I had the same thing with my Beta. It wasn't out by a lot so I taught myself not to look at it and worry. My assumption was that the wheel had been laced with a bit of an offset. Loosening all the spokes on one side and tightening on the other should have fixed it, but with no experience of wheel-building I could have made it a whole lot worse. So I left it. Quote Link to comment Share on other sites More sharing options...
katoom400 Posted February 28, 2023 Author Report Share Posted February 28, 2023 On 2/28/2023 at 11:37 AM, faussy said: Both replies above are correct, depending on what you mean by offset, i.e. does the wheel point straight ahead but is closer to one fork leg than the other, or is the wheel in the centre of the fork legs but point of at a angle? Expand It is visibly offset (not at an angle) to the right side. Quote Link to comment Share on other sites More sharing options...
faussy Posted February 28, 2023 Report Share Posted February 28, 2023 (edited) On 2/28/2023 at 7:53 PM, katoom400 said: It is visibly offset (not at an angle) to the right side. Expand It has most likely be respoked (possibly due to a bent rim) at some point and someone did a bad job. If the spindle spacers were wrong your disc wouldnt line up in the caliper Edited February 28, 2023 by faussy Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 1, 2023 Report Share Posted March 1, 2023 Possibly a wheel from another make of bike - if you bought it second hand Quote Link to comment Share on other sites More sharing options...
tshock250 Posted March 2, 2023 Report Share Posted March 2, 2023 On 3/1/2023 at 9:31 PM, jimmyl said: Possibly a wheel from another make of bike - if you bought it second hand Expand Mine was like that from new. Quote Link to comment Share on other sites More sharing options...
PAULIE Posted March 12, 2023 Report Share Posted March 12, 2023 On 2/28/2023 at 7:53 PM, katoom400 said: It is visibly offset (not at an angle) to the right side. Expand What was found to be the issue? Quote Link to comment Share on other sites More sharing options...
katoom400 Posted March 13, 2023 Author Report Share Posted March 13, 2023 On 3/12/2023 at 3:31 PM, PAULIE said: What was found to be the issue? Expand no idea, going to have the wheel re laced. Quote Link to comment Share on other sites More sharing options...
