Re spray tank
RIBSIE
Cracking is not usually the problem as there are flexible Additives for 2K paint (and plastic primers)
The problem with painting a plastic tank is usually that petrol fumes bleed through the plastic and cause the paint to bubble and lift off. ( Can do the same to stickers)
However , I have seen a couple of plastic tanks painted where the paint has stayed okay, I don't know if this is just luck or if the type of plastic or it's thickness make a difference ?
  • Like 2
Hi following on from trying to spray the tank I now know the poss problems involved , my bike is a montesa 200 with the red plastic tank is it poss to convert it to the alloy tank and a new cover as I was wanting to go for the white look would these fit or are all models different sizes ,
thanks ribsie
