Txt pro , clutch pack thickness and clutch slip
garydwall
Hello,
I have my clutch pack at 9.74 mm for a 2009 Pro.
From what I read the tolerance is 9.75 to 9.85.
My finger height however is at 10.50
I find the clutch slips in 5th and 6th gear.
The steel plates I have fitted are 1.5mm and 1.6 mm.
What do people suggest,  I don't want to make the clutch too heavy but obviously need to stop it slipping. The finger height seems to be quite out of range....
Thanks in advance.
Gary
if the pack is ok condition, id probably put a thicker steel plate/(s) in to pack the thickness out
if the packs below thickness its never going to be brilliant, alternatively could run a thicker spring ring, but this will make the clutch heavier.
Ive found finger height to be more important on a gasser than the pack thickness but everyone has their own experiences
  • Thanks 1
I believe it was 17 mm. It needs to be thinner to get that height. The easiest way is to get the bike warmed up, stick it in fourth gear against a wall and give the clutch hell. Otherwise there is a few videos to show how to do it by hand. When the pro first came out you could get as small as a 1.3. I save all I come across, must have enough to be a deck of cards.
  • 1 year later...
Txt racing 2021
I have a similar problem ,I have fit new soaked plates and got a Measure of 9.98,but when back together the fingers are loose ,is this right ?
I seem to get alot of clutch rattle when not engaged ,is this why ?
  On 6/9/2024 at 2:16 PM, robbo7 said:
Txt racing 2021
Expand
Yes, on both questions.
