lowside Posted April 19, 2023 Report Share Posted April 19, 2023 Just looking at the maintenance schedule, it says you should replace the gearbox oil after every ride. I wasn't expecting that and it sounds excessive. It's a Fajardo rep if that matters. How often would you chaps change the gearbox oil, typically? I'm a novice rider just starting out. Thanks Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted April 19, 2023 Report Share Posted April 19, 2023 That sounds crazy! Every 40 hours seems more reasonable to me, which is what is in the Beta owner's manual. It's about what I have done with all my bikes but I don't get obsessive about it and probably run over sometimes. On the other hand, I probably overestimate how many actual riding hours there are in a typical trial. 2 Quote Link to comment Share on other sites More sharing options...
lowside Posted April 19, 2023 Author Report Share Posted April 19, 2023 Thats what I thought to be honest yet there is definitely a dot in the "every ride" column. I also thought it might be a typo or translation error, but apparently not. I'll just do it every few days out. Quote Link to comment Share on other sites More sharing options...
