JoshN Posted April 20, 2023 Report Share Posted April 20, 2023 Hi All, Help please. I've read through the other forums on this topic but I'm still stuck. I've got a 2022 Beta Evo 2t with, I'm told, about 6 hours on it. I just purchased the bike last week. I noticed the few short rides around the driveway that the cooling fan did not turn on. The other day after about 30ish minutes of riding around the driveway the bike started to spit coolant as it was over heating. I wired a bypass around the thermal switch (unplugged and connected the two wires) and the fan turns on fine. I then assumed it was the thermal switch so ordered a new OEM Beta Evo thermal switch. I installed the new switch last night (very straight forward), refilled the coolant per instructions in Beta Evo manual and went for another ride. Again after about 30 minutes the bike started to spit coolant out the overflow and the cooling fan still fails to come on. I then rechecked and with the bypass the cooling fan will turn on. Besides the thermal switch and general electrical connectivity, what else could be going on? Is it possible to have received a new faulty thermal switch? I do have an electrical tester (basic) but would need some instruction on what else to test for. Any ideas? Here is the electrical diagram per the 2022 Beta Evo owners manual: Can't get image to upload, will try again. Quote Link to comment Share on other sites More sharing options...
JoshN Posted April 20, 2023 Author Report Share Posted April 20, 2023 Went out and rode the bike around again until hot, put the multimeter on the thermo switch and get nothing, just like the old one. Faulty switch again? Again, the fan works the moment I close the circuit by bridging the terminals. Quote Link to comment Share on other sites More sharing options...
lowside Posted April 20, 2023 Report Share Posted April 20, 2023 Give Beta a shout. All the information I've read is that they are very helpful, even if a bike is bought used. Someone may well help you here (great bunch on this forum), but theres no harm in asking Beta directly. Quote Link to comment Share on other sites More sharing options...
pauls320 Posted April 20, 2023 Report Share Posted April 20, 2023 Possible issues with water pump not circulating coolant ? Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 20, 2023 Report Share Posted April 20, 2023 Its May, just run it with the bypass Its not going to hurt it. Maybe by winter someine will have it figured out. Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 20, 2023 Report Share Posted April 20, 2023 P.S . You have to leave a little air gap, so do not fill all the way or any trials bike eill spit out coolant as they have no over fliw tank. 1 Quote Link to comment Share on other sites More sharing options...
JoshN Posted May 23, 2023 Author Report Share Posted May 23, 2023 Okay, well I had just wired in a switch to manually run the fan for the last few weeks. I ordered a new thermo switch from beta and checked it with a continuity tester before installing. It worked great. Second install was quick and everything is working now. It was just a bad part from beta. FYI for others. Thanks all! Quote Link to comment Share on other sites More sharing options...
