DanyScorpa Posted April 23, 2023 Report Share Posted April 23, 2023 2016 300, with the updated 2018? "battery less" ignition, starts and runs 1st kick when adding a 12 volt source, no spark, no fuel pump without 12 volts added, when running at 1800-2000 rpm its charging at 14.4 volts, just seems to not be creating enough electricity for starting requirements.. Help! Quote Link to comment Share on other sites More sharing options...
gasser75 Posted July 7, 2023 Report Share Posted July 7, 2023 Had the same problem on my 2017, changed the capasitor and the problem was solved Quote Link to comment Share on other sites More sharing options...
