slowrider Posted April 26, 2023 Report Share Posted April 26, 2023 Bought the electronic ignition for my 199B, last year 350 and noticed the it needs a spark plug that has the threads on top instead of the modern style plug for the boot to fit, I am using an NGK BPR4ES. Is there a plug that will work with this boot or do I need to convert the boot? Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 26, 2023 Report Share Posted April 26, 2023 Does to top of the plug not screw off ? 1 Quote Link to comment Share on other sites More sharing options...
slowrider Posted April 26, 2023 Author Report Share Posted April 26, 2023 On 4/26/2023 at 9:20 PM, b40rt said: Does to top of the plug not screw off ? Expand No, few plugs today do. Need to find one that does or change the boot Quote Link to comment Share on other sites More sharing options...
stpauls Posted April 27, 2023 Report Share Posted April 27, 2023 On 4/26/2023 at 10:52 PM, slowrider said: No, few plugs today do. Need to find one that does or change the boot Expand NGK BPR4ES 7222 Spark Plug Copper Core (gsparkplug.com) Quote Link to comment Share on other sites More sharing options...
slowrider Posted April 27, 2023 Author Report Share Posted April 27, 2023 On 4/27/2023 at 8:55 AM, stpauls said: NGK BPR4ES 7222 Spark Plug Copper Core (gsparkplug.com) Expand That is the plug I have and the top does not unscrew on top, need a plug that will unscrew at the top allowing me to use use the threaded part in the boot Quote Link to comment Share on other sites More sharing options...
slowrider Posted April 27, 2023 Author Report Share Posted April 27, 2023 Think I found the answer BP5ES 1 Quote Link to comment Share on other sites More sharing options...
faussy Posted April 27, 2023 Report Share Posted April 27, 2023 You have a plug with a solid terminal. You can get the same plug either threaded or with a removable nut, no need to change the heat range if you dont want to Quote Link to comment Share on other sites More sharing options...
slowrider Posted April 27, 2023 Author Report Share Posted April 27, 2023 On 4/27/2023 at 3:32 PM, faussy said: You have a plug with a solid terminal. You can get the same plug either threaded or with a removable nut, no need to change the heat range if you dont want to Expand Good to know Quote Link to comment Share on other sites More sharing options...
model80 Posted June 4, 2023 Report Share Posted June 4, 2023 On 4/27/2023 at 2:18 PM, slowrider said: Think I found the answer BP5ES Expand NGK BP5ES Champion N11YC Have been the recommended spark plugs to fit to a Sherpa T since day one. Quote Link to comment Share on other sites More sharing options...
