stpauls Posted May 2, 2023 Report Share Posted May 2, 2023 Honda TL 125 Q1. Has anyone replaced the points ignition on a Honda TL125 to an electronic ignition system? Q2. Has anyone used a Pitbike ignition to convert points ignition to an electronic ignition system on any other make or model? Thanks 1 Quote Link to comment Share on other sites More sharing options...
Travisb Posted June 27, 2023 Report Share Posted June 27, 2023 (edited) Not meaning to hijack this post…I have similar interest in a TL125 conversion kit. FWIW, I recently emailed electrex world in the UK who sold me an electronic ignition conversion kit for a ‘72 XL250, but they replied that they do not sell a conversion kit for the TL125. Edited June 27, 2023 by Travisb Clarity Quote Link to comment Share on other sites More sharing options...
stpauls Posted June 27, 2023 Author Report Share Posted June 27, 2023 (edited) CB125 Archives - Charlie's Place (charlies-place.com) See Honda XL125 Edited June 27, 2023 by stpauls Quote Link to comment Share on other sites More sharing options...
Travisb Posted June 27, 2023 Report Share Posted June 27, 2023 (edited) Thank you stpauls for this post. I did not see the TL125 listed so will inquire directly with the supplier. Perhaps there is more commonality between TL125 and XL/CB125 than I know, at least in the ignition systems. Edited June 27, 2023 by Travisb Typo Quote Link to comment Share on other sites More sharing options...
Travisb Posted June 27, 2023 Report Share Posted June 27, 2023 Reply from Charlie’s Place to TL125 compatibility of 3.6 Ignition Conversion kit (listed for CB/XL125) to TL125 inquiry… ”The system only works with a battery. If you wanted to run one at total loss just dedicated to the ignition system you could do it that way. But it wont work with the stock system which has no battery.” Quote Link to comment Share on other sites More sharing options...
lemur Posted October 9, 2023 Report Share Posted October 9, 2023 1 hour ago, jackyma09 said: 1. When converting from points to electronic ignition, you’ve got two options. You can either convert your existing distributor or you can install a new distributor. 2. You can convert from points to electronic ignition by removing the old points components from inside your distributor and replacing them with new ones. Ignition Distributor 🤔 does not exist unless you have multiple cylinders, single cylinder engine has a single ignition pickup coil to replace the single breaker points (aka trigger coil) Quote Link to comment Share on other sites More sharing options...
