Beamish RL fork question
djr
Hello,
Has anybody replaced the leading axle forks on a Beamish/RL with straight forks ?
The reason I ask is because the stantions on mine need re-chroming , £200 ish seems to be the going rate , but I have a spare pair of better Ossa MAR & Yamaha trials forks , and several wheels.
so would probably only need to buy some suitable yokes that go with the forks that I am thinking of using, to get somewhere near the right geometry.
I think I have seen this change from straight to leading axle on some other bikes ( and vice versa) but can't remember seeing a Beamish that has been changed.
I have access to a lathe & mill, so some small mods won't be a problem
Thanks
  On 5/9/2023 at 1:54 PM, teamferret said:
There's a good chance that the ossa fork stantions etc will fit nicely into the RL bottoms
Expand
Thanks,
I was thinking that today- nothing to lose in stripping 1 fork leg down on each set and doing some measuring.
Measured the O.D. of the Suzuki stantions today - 1 is 34.95mm , the other 34.8mm ( same readings in multiple places, not just measured in one place)
So maybe the forks have already had some work ?, which is not surprising for its age
  On 5/9/2023 at 5:57 PM, djr said:
Thanks,
Expand
The Suzuki ones are all smaller in Diameter
Expand
Thanks,
So should the Suzuki stanchions be 34.8mm or 34.95 ?
I have one at 34.8, the other 34.95
For comparison, I measured the 4 Ossa fork stanchions I have , and they measure - 34.95, 35.00, 35.00,35.05
So the Ossa ones are within 0.05mm of of the nominal size of 35mm
But the Suzuki vary by 0.15mm, I would have expected them to be closer
( All measurements taken with micrometer in several places, not one place)
The 2 different sizes make me think one stanchion has been replaced ?
  On 5/10/2023 at 7:29 PM, djr said:
Thanks,
Expand
There is variability in tube diameter when tubes are made new and when they are re-chromed. The process of finishing them (centreless grinding) is not a precision process, nor does it need to be.
Expand
Not where I worked, we worked to microns (+/- 0.002mm)!
Edited by suzuki250
Hello Suzuki 250
You commented that the Suzuki stantions are a smaller diameter than 35mm , could you tell me what that diameter is please ?
As I mentioned, I have one measuring 34.8mm , and the other 34.95mm, is one the correct size , or are both wrong ?
Thanks
  On 5/11/2023 at 5:34 PM, djr said:
Hello Suzuki 250
Thanks
Expand
I'll measure mine tomorrow and let you know tomorrow
Edited by suzuki250
Expand
Thanks
All interesting info
I am not a qualified engineer, and I have never been a motorcycle  fork manufacturer, so- I DON'T KNOW what an acceptable variation in size is for fork stanchions.
Out of curiosity I have measured the 9 pairs of forks I have. (Kawasaki, Yamaha, Suzuki,Ossa,can am) all are 1970s & 1980s
Only 1 pair are within 0.02 of each other , the rest are 0.05 - 0.15mm different to each other.
Most are undersize, but a couple are 0.05 oversized.
( Measured in multiple places with a micrometer, not one place with a Lidl Vernier)
I don't know what the correct tolerance is for fork stanchions, but all the forks I own don't appear to be made to micron tolerance.
Perhaps with modern manufacturing, the tolerances are better now on a new bike ?
  • 3 months later...
If anyone is interested, I did eventually finish this job recently by fitting some betor stanchions I had into the Suzuki sliders.
Only problem being the sliders needed reaming on lathe to allow the betor stanchions to fit without sticking.
I know there are tolerances & variations, but after measuring several Suzuki forks they all seem to be closer to 1.3/8inch (34.93mm) than 35mm.
This is probably silly, but I am wondering if they are actually made to an imperial size?
All the other nominally 35mm forks I have, although they vary in size most are close to or just over 35mm.
