Andy B Posted May 27, 2023 Report Share Posted May 27, 2023 Hi folks, I'm just in the process of rebuilding a rear kick 200 and I've found someone has been in before! The gearbox is missing thrust washers/shims on both shafts. I can find the part numbers but no sizes? anybody have a source or know the exact size of 250.43.8060. There was no washer in between the main bearing and crank number 250.42.5090 either? I'm being careful and taking my time building it so don't want to omit parts. I'll check end float etc as I get it back together. Cheers gentlemen. Quote Link to comment Share on other sites More sharing options...
mrtmartinp Posted May 30, 2023 Report Share Posted May 30, 2023 Hi Andy, I have an original dealer parts list if you needs the refs for the shims, let me know and I can scan them. Attached may help for now. Probably used in other Fantic engines e.g. Parts specific to the 200 (156 rear kick) start with 350. Probably find the shims are common to the 125 (FM250 250.) Not sure if Bill Pye at Frankfield Garage is still trading if any help. Fantic 125-200.pdf Quote Link to comment Share on other sites More sharing options...
