TL250 Front Sprocket Retention Hardware Install
mcman56
Can someone clarify how to install the front sprocket retention hardware for a TL250?. There is a flat washer with cut outs to slide on the spline.  There is a second washer with similar cutouts which also has some horizontal protrusions that will mate with the first washer.  However, I don't see how these two washers can mate once on the spline.  Then there is an e ring that fits but is not a tight fit in the groove on the spline.
