New EM app
nacho73
On 2/9/2025 at 2:23 PM, konrad said:
I added some content on EM Connect settings here: https://www.electricmotiontech.com/home/em-epure-race/controller/em-connect#h.twdhui88af1z  Because I don't have a bike with EM Connect, it's all from a theoretical perspective.  I'd appreciate any real-world feedback on my descriptions.
Well... thank you for the work you've put into this website so far.  I can add that "I think you must perform a “SEND” for each setting you change, and definitely before leaving a page." is true - for example if you make a change to map1 w/o hitting "send" and then go to map 2, you will lose the change to map 1.  Also, the "save" button is ONLY found on General tab, but you must click "save" after "sending" changes to any maps or you will lose the map settings w/ a power cycle.  In addition, you can navigate between map setting pages by clicking the tab header OR by swiping left or right.  I discovered how easy it is to perform errant swipes with very little screen contact which ends w/ frustrations of changing unintended maps.
Thanks!  Your comments make complete sense, and I altered my description to reflect your comments.  Basically, Send affects the controller's RAM.  Whereas Save writes those changes to its flash memory.
