robson Posted July 12, 2023 Report Share Posted July 12, 2023 I have already managed to burn my leg at header of my gasgas 300 txt when I was riding in short pants so I thought I will wrap in thermal tape to isolate it, any issues with that? Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 12, 2023 Report Share Posted July 12, 2023 Either way you are going to burn yourself. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 13, 2023 Report Share Posted July 13, 2023 Yes you can wrap it. You would not be the first. The negatives are corrosion, weight and appearance Quote Link to comment Share on other sites More sharing options...
robson Posted July 13, 2023 Author Report Share Posted July 13, 2023 56 minutes ago, feetupfun said: Yes you can wrap it. You would not be the first. The negatives are corrosion, weight and appearance what corrosion and what weight? this will be fiber glass wrap Quote Link to comment Share on other sites More sharing options...
lemur Posted July 13, 2023 Report Share Posted July 13, 2023 Glass weave holds water, water promotes rust if the header isn't alloy and contain iron. When glass wrap gets wet and hot that makes steam and steam can still burn you, Header temperature on a 2-stroke in far less then a 4-stroke, you'd be burning all of your riding pants if it was a 4-stroke. A heat shield that stands off the header pipe works far better at reducing heat transfer. Jitsie sells carbon fibre heat shields and they work great. If you do wrap it start your wrap at the rear and wrap forward towards the cylinder head, that way the layers will over-lap like fish or snake scales and the wrap material will catch less dirt spray off the front wheel. 1 Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted July 17, 2023 Report Share Posted July 17, 2023 Don't ride in short pants? 1 Quote Link to comment Share on other sites More sharing options...
endurofinn Posted July 17, 2023 Report Share Posted July 17, 2023 Just buy a header cover from Jitsie. Looks good and does the trick. Quote Link to comment Share on other sites More sharing options...
