miner Posted July 23, 2023 Report Share Posted July 23, 2023 Is there an end float dimension/spec for the crank when refitted the casings? Doing ok with the exploded parts diagrams and mechanical nous… but want to check this one before I pull the crank and bolt it back up. Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 23, 2023 Report Share Posted July 23, 2023 Not that I ever remember. Once it is buttoned up there is not much room to move.Biggest thing is getting the two shafts and shift drum to to fit right. 1 Quote Link to comment Share on other sites More sharing options...
miner Posted July 24, 2023 Author Report Share Posted July 24, 2023 Cool. Checked the 300 KTM manual for comparison, just says to fully butt it up before putting the other case on. Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted July 24, 2023 Report Share Posted July 24, 2023 There MUST be some, we can call it "endfloat". Normal is 0.25-0.5 mm to compensate for heat variations etc. It does not make any harm at all. Quote Link to comment Share on other sites More sharing options...
brt650 Posted August 13, 2023 Report Share Posted August 13, 2023 If your replacing the main bearings, the flywheel side bearing has an oil drain hole in it. It needs to line up with the drain back hole to the gearbox area. It’s the lower one. Actually, the new style bearings, from late 2003 on , have a drain hole drilling in them. The right side doesn’t need to be lined up. Quote Link to comment Share on other sites More sharing options...
miner Posted August 13, 2023 Author Report Share Posted August 13, 2023 The main bearings were ok, just swapped out the gearbox bearings as a couple of them were grumbly. Quote Link to comment Share on other sites More sharing options...
