Crank End Float (07 TXT Pro 250)
miner
Is there an end float dimension/spec for the crank when refitted the casings?
Doing ok with the exploded parts diagrams and mechanical nous… but want to check this one before I pull the crank and bolt it back up.
  • 3 weeks later...
If your replacing the main bearings, the flywheel side bearing has an oil drain hole in it. It needs to line up with the drain back hole to the gearbox area. It’s the lower one.
Actually, the new style bearings, from late 2003 on , have a drain hole drilling in them.  The right side doesn’t need to be lined up.
