Rear hub widths
tony27
Is there a difference in width of the hubs between the older rim taped wheels & the flanged wheels?
I recently bought a flanged rear wheel that has a polished hub & dark grey rim which I think would be from a 2019 20th anniversary model which there doesn't seem to have a parts book available online. The only hubs for the flanged wheels I can find part numbers for are fluro so I can't the numbers with the earlier polished hubs, none of the parts books show the bearing spacer so I can't even use that as a comparison
I have used the wheel in my 04 Jarvis replica & noticed the disc sits closer to the inside edge of the caliper than the original wheel & the wheel is a tighter fit in the swingarm so I'm looking for reasons as to why this is the case
