75W gear oil???
robson
hi, why GasGas doesn't recommend gear oil with full specs like e.g. 75W90  but they do only 75W ?
is that second part doesn't matter or what?   I managed to get actually oil with just 75W specs but I got also 75W90
and wonder which one to use :)
Edited by robson
Different types of lubricants use different scales:
... when you see 2 numbers divided by the W that indicates an SAE multi-grade blended oil, like you would need if you were accommodating a wide operating temperature range.
14 minutes ago, robson said:
so basically I can use either one?    75W90 as well?
Basically, your 75W90 gear oil will be a little thicker at cold temperatures then recommended by the manufacturer.
Personally I would be using ISO 46 UDT hydraulic oil because then my clutch won't drag even at cooler operating temps.
I like the NILS oils and would consider the clutch trials oil myself if you have a good place to get it.
I have used Maxima 75w gear oil in our Gas Gas 125 in the past and it worked well but I did like thinner better myself, however the clutch action is a little faster that way and the 75w slowed the engagement a bit and my daughter liked that a bit better when she was younger and learning.
Example: (no affiliation just the only place in the US I know of I can get it)
https://abadtrials.com/collections/lubricants-1/products/nils-clutch-trial
Edited by jonnyc21
