Isaac Posted September 3, 2023 Report Share Posted September 3, 2023 Hello everyone, I did search the site and did not find anything relevant, so I apologize if this question is a repeat. I have a 1997 gas gas jtx 270 (i think, might be a txt?) either way the gas tank is toast, it is cracked and has a hole in it. As we all probably know HDPE plastic is nearly impossible to repair. ( I did try epoxy) So I need a replacement. I have searched online a fair bit for a replacement tank with no luck. Does anyone know where I can get any sort of tank that will work? Will tanks from other gas gas models and years fit? Are there aftermarket options? Has anyone used a generic tank of some kind? Any help or leads would be greatly appreciated. Many thanks, Isaac Quote Link to comment Share on other sites More sharing options...
kwackerdave1 Posted September 4, 2023 Report Share Posted September 4, 2023 Try Trials Bike Breakers UK or Allen’s Used Trials spares. Both on F/B. For a new tank try John Shirt Motorcycles who was the importers. 1 Quote Link to comment Share on other sites More sharing options...
