doddy Posted October 9, 2023 Report Share Posted October 9, 2023 good afternoon i need to change my 4rt ( actually a 4ride) shock linkage bearings; does anyone have any tips ? tia john Quote Link to comment Share on other sites More sharing options...
lemur Posted October 9, 2023 Report Share Posted October 9, 2023 Rebuild the old one with drawn cup needle bearings and seals sourced from a local bearing supply store, the linkage is garbage if the hole for the bearing gets smashed out of round. The stock bash plate does a poor job of protecting the linkage. 1 Quote Link to comment Share on other sites More sharing options...
doddy Posted October 9, 2023 Author Report Share Posted October 9, 2023 18 minutes ago, lemur said: Rebuild the old one with drawn cup needle bearings and seals sourced from a local bearing supply store, the linkage is garbage if the hole for the bearing gets smashed out of round. The stock bash plate does a poor job of protecting the linkage. how difficult is it to remove the old ones ? Quote Link to comment Share on other sites More sharing options...
lemur Posted October 9, 2023 Report Share Posted October 9, 2023 5 hours ago, doddy said: how difficult is it to remove the old ones ? Easy, drive them out with a hammer and a socket wrench. or press them out with a vise and two sockets. Two bearings in each end of the dog bone for a total of 4 bearings plus 4 seals. Quote Link to comment Share on other sites More sharing options...
lemur Posted October 9, 2023 Report Share Posted October 9, 2023 Jitsie sells the cheapest complete replacement dog bone assembly, Honda wanted about 30% more $ last time I bought one. Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 9, 2023 Report Share Posted October 9, 2023 All balls has the cheapest complete bearing kit. The cheapest solution is regular service. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 9, 2023 Report Share Posted October 9, 2023 Also if you get the CSP dog bone you can get the protector plate too. 1 Quote Link to comment Share on other sites More sharing options...
lsv Posted October 12, 2023 Report Share Posted October 12, 2023 On 10/9/2023 at 9:26 PM, lemur said: Two bearings in each end of the dog bone for a total of 4 bearings plus 4 seals. It is VERY important to also check/replace the two more bearings that are in the swinging arm, these,if neglected can result in a very expensive repair....... On 10/9/2023 at 11:12 PM, lineaway said: The cheapest solution is regular service. Whilst agreeing with the above statement I would be wary of On 10/9/2023 at 11:12 PM, lineaway said: All balls has the cheapest complete bearing kit. May be cheapest but they aren't the correct needle rollers in their kit - should be full compliment type.............. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 12, 2023 Report Share Posted October 12, 2023 They may not be correct compared to the stock bearings. I have had them in my 301 for 18 months and still tight as the bike was new. Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted October 12, 2023 Report Share Posted October 12, 2023 On 10/9/2023 at 3:39 PM, doddy said: how difficult is it to remove the old ones ? I don't know about a Montesa specifically, but I always warm up aluminium housings with a hot air gun before removing or fitting bearings. Quote Link to comment Share on other sites More sharing options...
lsv Posted October 12, 2023 Report Share Posted October 12, 2023 8 hours ago, lineaway said: They may not be correct compared to the stock bearings. I have had them in my 301 for 18 months and still tight as the bike was new. That's as maybe, but I wouldn't think Honda/Montesa would spec full compliment if they didn't think it was necessary. Full compliment have a greater load rating I believe............ Quote Link to comment Share on other sites More sharing options...
jannick Posted January 24, 2024 Report Share Posted January 24, 2024 (edited) Start by removing the rear wheel and any other components that might be in the way of the shock linkage. Then, unbolt the shock linkage from the frame and swingarm. Use the good bearings puller to remove the old bearings from the linkage plates. Be careful not to damage the plates or the bearings themselves. Edited January 25, 2024 by jannick Quote Link to comment Share on other sites More sharing options...
