Harry44 Posted October 24, 2023 Report Share Posted October 24, 2023 Looking at getting into trials as well as running an enduro bike, do the trs bikes use a wash cover on the airbox to protect from water? Quote Link to comment Share on other sites More sharing options...
lemur Posted October 24, 2023 Report Share Posted October 24, 2023 Under the saddle/fender, they have a TwinAir oiled foam air filter with a small piece of plastic bolted immediately over the filter element so water doesn't drop down directly on the filter, the air box has a drain in the bottom with a one way flap valve to let water out, but sometimes that gets plugged with mud so you need to clean the air box occasionally. TRS seem to do well in water crossings, way better than some brands. On some other makes the rear wheel funnels water into the air intake and the filter fills with water quickly. TRS air box has a considerable volume to fill before the filter becomes submerged. 1 Quote Link to comment Share on other sites More sharing options...
faussy Posted October 25, 2023 Report Share Posted October 25, 2023 Ive only ever seen wash cvoers for gasgas and montesa. I would never let a lack of a wash cover influence what bike to buy though Quote Link to comment Share on other sites More sharing options...
Harry44 Posted October 25, 2023 Author Report Share Posted October 25, 2023 Understood, just strange coming from an mx / enduro background, the first thing you buy when acquiring a bike is a washcover. Quote Link to comment Share on other sites More sharing options...
faussy Posted October 25, 2023 Report Share Posted October 25, 2023 (edited) Ive never really thought about missing one. Trials airboxes are a little more water tight than a mx airbox. Yes, water gets into both when using a power washer, but with a trials bike its usually so little that its never going to get through the air filter as well. If however i want to wash the inside of my airbox, i usually just take the whole airbox off. This is on my gg though which is a 30 second job, dont know how hard it is to take a trs airbox off. I guess it would be handy for those really muddy times you want to wash the inside of airbox along with washing the bike, howver id be so paranoid of water getting in id probably end up taking the airbox off afterward to dry the inlet hose lol Edited October 25, 2023 by faussy Quote Link to comment Share on other sites More sharing options...
bikerpet Posted October 31, 2023 Report Share Posted October 31, 2023 The TRS airbox sometimes comes from the factory with an imperfectly sealed join between upper and lower sections. It's pretty trivial to split the join, add sealant to the voids and screw it back together if you find dirt/water getting in. Once it's properly sealed I've not seen any water get into the airbox from washing or riding in non-drenching conditions. Removing the airbox is just four easy-to-get-to socket screws and a hose clamp. No big deal to wash the inside as needed - similar to GasGas. Quote Link to comment Share on other sites More sharing options...
Assgas Posted March 30, 2024 Report Share Posted March 30, 2024 (edited) On 10/24/2023 at 10:47 PM, lemur said: Under the saddle/fender, they have a TwinAir oiled foam air filter with a small piece of plastic bolted immediately over the filter element so water doesn't drop down directly on the filter, the air box has a drain in the bottom with a one way flap valve to let water out, but sometimes that gets plugged with mud so you need to clean the air box occasionally. TRS seem to do well in water crossings, way better than some brands. On some other makes the rear wheel funnels water into the air intake and the filter fills with water quickly. TRS air box has a considerable volume to fill before the filter becomes submerged. Expand My 21 300 air box filled right up with water and stayed in there till I vacuumed it out I did not see how water could get out Edited June 1, 2024 by Assgas Quote Link to comment Share on other sites More sharing options...
lemur Posted March 31, 2024 Report Share Posted March 31, 2024 On 3/30/2024 at 11:50 PM, Assgas said: My 21 300 air box filled right up with water and stayed in there till I vacuumed it out I did not see a water could get out Expand There is a drain hole in the bottom and you will find it once you remove the air box and completely clean it, will require some significant digging to clear the hole. Quote Link to comment Share on other sites More sharing options...
