robson Posted November 6, 2023 Report Share Posted November 6, 2023 Hi, thinking about getting bigger tank for my 300 txt but wonder if it comes with tab etc and it's easy swap or I need to installs omething from the old one? Quote Link to comment Share on other sites More sharing options...
faussy Posted November 6, 2023 Report Share Posted November 6, 2023 (edited) Is this for a pre 23, post 12? No they dont come with a tap, though they are easily swapped after removing the cobra clip. They use the same top bolt. You need to install a bit of foam tape where it meets the airbox to stop it rattling, like the standards. Heat refective tape is discretionary IMO Edited November 6, 2023 by faussy Quote Link to comment Share on other sites More sharing options...
robson Posted November 6, 2023 Author Report Share Posted November 6, 2023 yes it's 2021 - ok thanks, also i have seen it's black plastic without any stickers etc Quote Link to comment Share on other sites More sharing options...
faussy Posted November 7, 2023 Report Share Posted November 7, 2023 (edited) yes, and you cant buy a sticker for them. Some fit the standard sticker but its not that great looking. If youre on fb its possibly worth contacting some expert gasgas riders or putting up a post. Now that the new model has changed tanks ive seen some riders sell their old ones from when they had them fitted at the scott and ssdt Edited November 7, 2023 by faussy Quote Link to comment Share on other sites More sharing options...
manwithgun Posted November 8, 2023 Report Share Posted November 8, 2023 On 11/6/2023 at 7:51 AM, robson said: Hi, thinking about getting bigger tank for my 300 txt but wonder if it comes with tab etc and it's easy swap or I need to installs omething from the old one? For the pre-23', look up the 2018 Gasgas Contact oem chassis parts list. The tank "kit" costs $330 USD and adds about a liter, bringing the total capacity to 3.5L. It includes the weather strip tape and adhesive heat shield. New oem petcock is only another $10. Use a fuel hose clamp (screw type/non-slotted) or oem crimp-on. Swapping between tanks only takes a minute (1 screw). There's even a no frills Contact tank sticker for an additional $30... 1 Quote Link to comment Share on other sites More sharing options...
