PatMc Posted November 15, 2023 Report Share Posted November 15, 2023 Evening All Recently bought a 2005 Gas Gas txt 250 pro.After a few rides about on it I’ve encountered some issues. It starts and runs fine but when it’s anyway warm and the engine stops it will , under no circumstances start again. At first I thought it was a coil pack , I replaced it with a new one and the issue is still there unfortunately. I fear it may be the stator at fault . It’s worth noting it’s using a Kokusan stator. Anybody on here had anything similar issues , any help or pointers will be genuinely appreciated. Thanks all Regards Pat Mc Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted November 15, 2023 Report Share Posted November 15, 2023 4 minutes ago, PatMc said: Evening All Recently bought a 2005 Gas Gas txt 250 pro.After a few rides about on it I’ve encountered some issues. It starts and runs fine but when it’s anyway warm and the engine stops it will , under no circumstances start again. At first I thought it was a coil pack , I replaced it with a new one and the issue is still there unfortunately. I fear it may be the stator at fault . It’s worth noting it’s using a Kokusan stator. Anybody on here had anything similar issues , any help or pointers will be genuinely appreciated. Thanks all Regards Pat Mc @PatMc Take the plug out and check its condition then clean it with a fine wire brush like you would use for cleaning suede shoes and blow it clean , make sure you get in the gap between the insulator and the part that is threaded on the outer surface. make sure the gap is 0.6 and the plug is a BPR5ES or Champion etc equivalent or a NGK Iridium BPR5 EIX. If the bike starts after you clean it and it was black in colour dry or wetish then you are probably running too rich a mix as in more fuel to air than the usual 14.7 ish air to 1 part fuel ratio This causes the plug to foul and your spark will be poor. If you have a Dellorto PHBL 26 BS carburettor then the fuel screw should be approximately 3 turns out from lightly closed by turning clockwise., turning anti clockwise adds fuel. check your pilot/slow jet and your main jet size are the recommended ones for your local weather conditions and elevation relative to sea level . Also make sure your filter is clean and not over oiled. Clean all electrical connectors and tighten bolts that have earth connectors. check wiring where it has crimped connectors etc. Take off the rubber plug cap by screwing it anti clockwise and check the condition of the coarse screw thread in the rubber plug cap and the core wire in the thick black HT cable that comes from the coil is able to make good contact with the plug cap core. Quote Link to comment Share on other sites More sharing options...
PatMc Posted November 15, 2023 Author Report Share Posted November 15, 2023 Thank you so so much for that info. I’m not hugely mechanically minded so there’s a not of info in that that should help . I’ll post on this thread how I fair out . Again thank you Regards PatMc Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted November 15, 2023 Report Share Posted November 15, 2023 27 minutes ago, PatMc said: Thank you so so much for that info. I’m not hugely mechanically minded so there’s a not of info in that that should help . I’ll post on this thread how I fair out . Again thank you Regards PatMc When the motor is hot and it will not start try using choke with NO throttle , if it does not start within 3 kicks then abandon that as it will just wet the plug and render it impossible to start . It is worth a try It used to work on my GasGas PRO of around that era when it would not start when hot. Good Luck. Quote Link to comment Share on other sites More sharing options...
PatMc Posted November 15, 2023 Author Report Share Posted November 15, 2023 I’ll certainly try that , will report back soon with some hopeful joy thanks mate 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 15, 2023 Report Share Posted November 15, 2023 An easy check of the fuel venting. Tank vent and carb vents Anything can happen. 1 Quote Link to comment Share on other sites More sharing options...
PatMc Posted November 15, 2023 Author Report Share Posted November 15, 2023 Thanks mate I’ll be back at it tomorrow and see how we go Quote Link to comment Share on other sites More sharing options...
