Ossa MAR rear brake set up
sidstevo
22 hours ago, sidstevo said:
Hi all.
Has anyone got a picture or diagram of how the rear brake cable connects to the pedal bar and the rear wheel.
Cheers
Sid
Sid to get a photo of the front end of the cable, the bike needs to be on it's side or upside down and my OSSAs are currently packed away. I'm not willing to unpack one of them until I'm convinced that you really need a photo. So here it is in words.
Pedal bar end:
The pedal bar arm has a receptacle for the end of the cable outer. The nipple on the cable inner fits into a holder on the frame.
Wheel end:
The brake plate arm attaches to the cable inner. The cable outer is held in a receptacle on the brake backing plate.
  • 2 weeks later...
On 12/16/2023 at 9:31 PM, sidstevo said:
Hi Ian
Many thanks for your help. Not seen a set up like it before. I can now crack on with the rebuild.
Much appreciated
Sid
If you are using the original chain Tensioner , then that needs to be assembled on to the brake pedal shaft at the same time, and I think this is all easier before the engine is fitted ?
