misterroy Posted December 31, 2023 Report Share Posted December 31, 2023 All the best for 2014. I bought a 2015 Sherco this December. Took it home and went up a nearby hill, no problem. It was in the back of the van overnight. I took it out, started it and rode about 200M down the road before the front brakes stopped me. A bit of forwards and backwards, and they were freed enough to get home. About a week later, the brakes stopped me again. Both of these days were cold, 0 to 5 °C.. When I got home, I pushed the pistons in, pulled the brake, etc. The front brake was fine on the next spin, but it was warmer. Is it a temperature problem? Quote Link to comment Share on other sites More sharing options...
lemur Posted December 31, 2023 Report Share Posted December 31, 2023 Best flush it out with fresh brake fluid. Brake fluid goes bad by taking on water, water freezes and boils, very bad for making ice or steam in the brake fluid which makes your brakes act badly. Quote Link to comment Share on other sites More sharing options...
tony27 Posted December 31, 2023 Report Share Posted December 31, 2023 Have had the brakes start dragging bad enough to stop if the clutch was pulled in on a downhill slope while on a trials bike only trail ride, was expecting it to be time to rebuild the calipers but replacing the fluid fixed it in the front, rear brake was also in need of new pads as they were pretty well worn. I'd start with pushing the pistons back in the caliper, replacing the fluid & pads if they're worn Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted December 31, 2023 Report Share Posted December 31, 2023 @misterroy You may have a front brake lever that has no free play causing the brakes to drag then the heat build up expands the fluid and it cannot return to the expansion tank IE the brake reservoir which then uses the brake calliper as its route to expand and applies the brakes. Make sure you have free play of about 1 mm between the lever and the little metal plunger that goes into the rubber boot at the Brake reservoir that is clamped on the handlebar. 3 Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted January 1, 2024 Report Share Posted January 1, 2024 19 hours ago, Tr1AL said: @misterroy You may have a front brake lever that has no free play causing the brakes to drag then the heat build up expands the fluid and it cannot return to the expansion tank IE the brake reservoir which then uses the brake calliper as its route to expand and applies the brakes. Make sure you have free play of about 1 mm between the lever and the little metal plunger that goes into the rubber boot at the Brake reservoir that is clamped on the handlebar. This happened to me when I got my first trials bike. I've always been obsessive (on karts and racing cars) about having a short-travel hard pedal so I adjusted the bike's brakes the same way. I went out for my first practice, twice around the car park and I fell off! The front brake had locked up. Very embarrassing.😳 Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted January 1, 2024 Report Share Posted January 1, 2024 12 minutes ago, trapezeartist said: This happened to me when I got my first trials bike. I've always been obsessive (on karts and racing cars) about having a short-travel hard pedal so I adjusted the bike's brakes the same way. I went out for my first practice, twice around the car park and I fell off! The front brake had locked up. Very embarrassing.😳 Most people do these kind of things if they are honest , I make lots of mistakes daily when I already know better its frustrating but at least we rarely make the mistakes more than twice , hopefully. Have a good evening. Quote Link to comment Share on other sites More sharing options...
