cdn280 Posted March 9, 2006 Report Share Posted March 9, 2006 I've got a light scratch on one of the ti-nitride?? coated fork tubes. Is there a temp/permanant repair for this, or is it new tube time ? Full length neoprene gators or some other protection may be in my future. Quote Link to comment Share on other sites More sharing options...
magicmat Posted March 9, 2006 Report Share Posted March 9, 2006 You saying that muck stracted it ? and not a sharp object in your gargae ?? Quote Link to comment Share on other sites More sharing options...
cdn280 Posted March 9, 2006 Author Report Share Posted March 9, 2006 (edited) You saying that muck stracted it ?and not a sharp object in your gargae ?? <{POST_SNAPBACK}> It would taken some sharp muck... more likely a brush against a rock or log. Ugh, i just realized what did it. The stand fell off a shelf in my trailer... Edited March 9, 2006 by cdn280 Quote Link to comment Share on other sites More sharing options...
araf Posted March 11, 2006 Report Share Posted March 11, 2006 Last pair of fork legs I got Nitride coated cost Quote Link to comment Share on other sites More sharing options...
cdn280 Posted March 11, 2006 Author Report Share Posted March 11, 2006 Thanks, I'm going to try the wet sanding if it causes any leaking. I just changed my fork oil and haven't seen it leaking ... yet. I only noticed it when I had them apart. A new tube is in the $200 range (less than 100 pounds), so its not as bad as I thought it might be. Quote Link to comment Share on other sites More sharing options...
cdn280 Posted March 23, 2006 Author Report Share Posted March 23, 2006 After meticulously cleaning everything and putting it back together with the old seals and Mobil1 ATF, I've done 2 1hr rides and no leaks... for now. I had some Mobil1 left over from a KTM fork oil change and thought I'd try it as it worked well there. Quote Link to comment Share on other sites More sharing options...
