Tallpaulself Posted January 21, 2024 Report Share Posted January 21, 2024 Hi all. I've seen it documented that later models have a gap between the left swing arm and the frame. Is this the same for older models? My 2002 txt 200 has roughly a 5mm gap Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted January 21, 2024 Report Share Posted January 21, 2024 7 hours ago, Tallpaulself said: Hi all. I've seen it documented that later models have a gap between the left swing arm and the frame. Is this the same for older models? My 2002 txt 200 has roughly a 5mm gap As long as you have the large pressed steel washers sitting in the rear swing arm spindle hole of the engine casings then the gaps between the outer swing arm pivot points and the frame do not matter as the engine casings as one unit keep the swing arm centered., the steel washers protect the casing edges from wear obviously. Quote Link to comment Share on other sites More sharing options...
Tallpaulself Posted January 21, 2024 Author Report Share Posted January 21, 2024 9 minutes ago, Tr1AL said: As long as you have the large pressed steel washers sitting in the rear swing arm spindle hole of the engine casings then the gaps between the outer swing arm pivot points and the frame do not matter as the engine casings as one unit keep the swing arm centered., the steel washers protect the casing edges from wear obviously. Yeah, got them in there and the casing pinch bolts tightened down. Just looks so wrong to have that gap. Thanks for the reply! Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted January 21, 2024 Report Share Posted January 21, 2024 (edited) 14 minutes ago, Tallpaulself said: Yeah, got them in there and the casing pinch bolts tightened down. Just looks so wrong to have that gap. Thanks for the reply! I know what you mean it does seem like it would be weakened by being like that but it works fine, I never saw a problem on one caused by the gap as long as the bushings and spindle are good. Edited January 21, 2024 by Tr1AL Quote Link to comment Share on other sites More sharing options...
