DavidSweden Posted January 27 Report Share Posted January 27 Today I drove the bike for the first time after rebuilding the engine, unfortunately there is a problem shifting the gears. There are a lot of false nuetral between the gears, is there is some way to adjust the shifter mechanism to get a smooth gear shift.... or have i made a mistake when reassembling the motor? Quote Link to comment Share on other sites More sharing options...
lemur Posted January 27 Report Share Posted January 27 Need a better description but if it shifts through every gear and the lever springs back to centre after shifting, you likely have it together right, how well everything slides is dependent on how careful you were on assembling all the sliding parts and condition of the shifter forks, bent or worn shift forks will cause imperfect movement of the spur gears but you should notice that on disassembly or by the metal shavings in the oil changes. What was the condition of the shifter forks when it was apart? Quote Link to comment Share on other sites More sharing options...
nh014 Posted January 27 Report Share Posted January 27 I suspect the shift eccentric may not be adjusted correctly. This is easiest to do with the clutch removed. Spin both shafts so that all 5 gears can be selected with a minimum of further turning of the shafts. The shift detent plunger and spring must be in place. Set the eccentric in the middle of its range. Now shift down into 1st and release the shift lever. If you see that the shift drum moves (ever so slightly) as you release the lever, then you need to adjust the eccentric. The plan is to have each downward movement of the lever put the shift drum in exactly the correct position. The shift detent plunger should not "assist" in rotating the drum even slightly, after you let go of the shift lever. Now pull the lever up into second gear. Release the shift lever. Once again, you should not see any further movement of the shift drum after you release the lever. If you do, then you are moving the drum too little, or too much, and that is what the eccentric adjusts for. 1 Quote Link to comment Share on other sites More sharing options...
DavidSweden Posted January 28 Author Report Share Posted January 28 Thanks nh014. Quote Link to comment Share on other sites More sharing options...
DavidSweden Posted February 4 Author Report Share Posted February 4 I adjusted the shifter drum but still have a problem shifting the gears. There are false nuetrals and the gears sometimes grind, also the gears lock and it takes a few trys to get the gears unlocked and shifting again. Any ideas what the problem is? Quote Link to comment Share on other sites More sharing options...
Pahrumprider Posted February 8 Report Share Posted February 8 Do you have a problem with it slipping out of gear and back into neutral? I had a '76 348 back in the early eighties and there was an aftermarket kit you could buy that might help. I can't for the life of me remember what I did to install it. Hopefully this gets read by somebody else that had the same problem and bought the kit. Quote Link to comment Share on other sites More sharing options...
DavidSweden Posted February 17 Author Report Share Posted February 17 Does anyone have some instructions on how to set uo the gearbox? Quote Link to comment Share on other sites More sharing options...
lemur Posted February 17 Report Share Posted February 17 4 hours ago, DavidSweden said: Does anyone have some instructions on how to set uo the gearbox? Do you still have the original manual? Almost certain it came with one like the 360VA did. Quote Link to comment Share on other sites More sharing options...
