New 01 280txt
Canyonman
Greetings and thanks for having me. Just acquired 01 280txt. Looking for manual, parts book, I understand it has diagrams for assembly. Also any info on what fits what; model to model, and which other manufacturers used this powerplant and extraneous pars. Thanks in advance
The swingarm is allow
21 hours ago, Canyonman said:
 less than 10 hours
I can tell.
The swingarm is alloy, but the frame is chrome plated steel. Engien and frame components youre going to be largely restricted to the years 97-02. Wheels, brakes, carburettor will be largely interchangebale with later years and other makes.
What are you going to do with it? If youre plannning on just pottering around thats ok, but if youre planning on doing a lot of crashing id try and find a cheap second hand rear mudguard on ebay or somewhere you can swap over when practicing or the like. You cant get new ones for that model, and the blue plastics are even rarer.
Btw your petrol tap is on reserve, off is the tab pointing back, on is down
Edited by faussy
  • Thanks 1
  • 4 weeks later...
