master68 Posted January 31, 2024 Report Share Posted January 31, 2024 Anybody use Amsoil Saber in their Beta trial bikes? What do you use as a premix? I am running non ethanol 90 Octane in bike. 1 Quote Link to comment Share on other sites More sharing options...
kurtas Posted January 31, 2024 Report Share Posted January 31, 2024 Key is to try and get an oil with a low burning temperature (flash point). Have a look at the oils in your shop and pick one that is on the lower end of the burning temperature as Trials motors generally don't get hot enough to correctly burn the most fantastic fully synthetic oils designed for race bikes. Quote Link to comment Share on other sites More sharing options...
master68 Posted January 31, 2024 Author Report Share Posted January 31, 2024 Thanks for info Quote Link to comment Share on other sites More sharing options...
lemur Posted January 31, 2024 Report Share Posted January 31, 2024 I have used Saber in everything 2-stroke for many years with no issue. Quote Link to comment Share on other sites More sharing options...
RonH Posted February 1, 2024 Report Share Posted February 1, 2024 I’ve heard that (using Saber) from many other riders because they mix @ 100:1, save money and have a cleaner burn. I’d like to be able to do that too but just can’t pull the trigger. I contacted Amsoil personally and asked, off the record, if I could but they closed the door on that and said to use Amsoil Dominator instead. Very trustworthy and competent people seem to use it with no problems but Amsoil clearly says not to. I wonder what the deal really is. I’m currently using Motorex at man. rec. @ 67:1 and wished things burned a bit cleaner. My bike is new with only about 4 hours on it and I pulled the head off to have a look. Everything was covered in carbon and oil. It smokes like crazy too. 2 strokes smoke, I get that, but am I missing out on something somewhere? Maybe it need to break-in more, I don’t know. Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 1, 2024 Report Share Posted February 1, 2024 If what your burning looks like crap, well it`s crap. I learned years ago all oil is not the same. Ran Bel Ray since I got it at distributor price. Then got to see motors stripped down. What an eye opener! Most are ****. Clean is clean. Good luck. Quote Link to comment Share on other sites More sharing options...
lemur Posted February 1, 2024 Report Share Posted February 1, 2024 The big difference between Saber and Dominator or Interceptor is that Saber 100:1 oil is too concentrated to use in an oil injection system. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted February 1, 2024 Report Share Posted February 1, 2024 On 1/31/2024 at 5:23 AM, kurtas said: Key is to try and get an oil with a low burning temperature (flash point). Have a look at the oils in your shop and pick one that is on the lower end of the burning temperature as Trials motors generally don't get hot enough to correctly burn the most fantastic fully synthetic oils designed for race bikes. Expand Where do you find the flash point? Is there a comparison chart somewhere? Quote Link to comment Share on other sites More sharing options...
Gray_side_up Posted February 1, 2024 Report Share Posted February 1, 2024 (edited) Pulled this from various websites. Edited February 1, 2024 by Gray_side_up Update Quote Link to comment Share on other sites More sharing options...
