oil change
jamesh
Have a look on motoswm for engine manuals, can't remember if there is one for the climber, but the bottom end is the same as swm 's.
On the bottom of the engine there is an alan key plug, remove to drain oil. Clean the magnet.  (Do NOT undo the hex nut)  Refill with 1 litre of ATF . Use some super expensive oil if you prefer.
On 2/1/2024 at 3:03 AM, lineaway said:
The hex nut is the detent for the shift drum. Good call b40rt. !!!
I think the hex nut is the kickstart spring locator, nothing good comes from undoing it 😂
Edited by b40rt
