Ninja Posted February 5, 2024 Report Share Posted February 5, 2024 Hi all I have the dreaded chrome drums on my 199b and need to fit some cast inserts, are there some available or is it a case of making some out of cast pipe ect. Quote Link to comment Share on other sites More sharing options...
bullylover Posted February 6, 2024 Report Share Posted February 6, 2024 Usually you will need to take the hub out of the rim then any good engineering shop should be able to do it. Ask around in Motorcycle shops near you or look on this page for ads if you`re in England. 1 Quote Link to comment Share on other sites More sharing options...
lemur Posted February 6, 2024 Report Share Posted February 6, 2024 Made a set of custom brake shoes for a friend that rode one of those, I used Thorndon XL elastomeric bearing plastic and it made the front brake powerful enough to do nose wheelies, unless you run them hot enough to melt the plastic, that was not so good 😆 Not saying I would recommend that exact modification unless you regularly ride in deep water, but it's worth mentioning that there is another way to approach the problem 🤔 1 Quote Link to comment Share on other sites More sharing options...
robido Posted February 7, 2024 Report Share Posted February 7, 2024 It Can be done with wheel complete. Had my fantic done without stripping . Quote Link to comment Share on other sites More sharing options...
Ninja Posted February 9, 2024 Author Report Share Posted February 9, 2024 Hi all Been chatting with a pal in our local bike club and he can line my drums on his lathe as it can take a 21jnch wheel,so tyres off and good to go. 2 Quote Link to comment Share on other sites More sharing options...
bfd Posted April 14, 2024 Report Share Posted April 14, 2024 What is the preferred shoe to work with the chrome? I rode an event with new Goldfren shoes and they are making good and even contact but don’t do the job.  Quote Link to comment Share on other sites More sharing options...
bullylover Posted April 15, 2024 Report Share Posted April 15, 2024 EBC brake shoes are the best ones off the shelf. 1 Quote Link to comment Share on other sites More sharing options...
