Mk1finks Posted March 12 Report Share Posted March 12 Hello, I am looking to purchase a PHBH26CS carburetor as I destroyed the threads that hold the bowl to the body on my 1997 montesa cota 315R Quote Link to comment Share on other sites More sharing options...
konrad Posted March 12 Report Share Posted March 12 So the body itself has a damaged thread? This part won't fix it? https://www.splatshop.co.uk/dellorto-float-bowl-nut.html If not, can you run a tap into the body and clean it up? Here's the entire carb with the BS suffix (your jetting may be different) https://www.splatshop.co.uk/dellorto-phbl-trials-carburettor.html Quote Link to comment Share on other sites More sharing options...
robido Posted March 13 Report Share Posted March 13 Try eurocarb Quote Link to comment Share on other sites More sharing options...
Mk1finks Posted March 13 Author Report Share Posted March 13 31 minutes ago, konrad said: So the body itself has a damaged thread? This part won't fix it? https://www.splatshop.co.uk/dellorto-float-bowl-nut.html If not, can you run a tap into the body and clean it up? Here's the entire carb with the BS suffix (your jetting may be different) https://www.splatshop.co.uk/dellorto-phbl-trials-carburettor.html No, the bolt is fine, the body lost the first 3 rows of threads the bolt goes into. I didn’t have the pin that holds the float flapper seated enough and it held the bowl from seating but I didn’t notice. So it wasn’t sitting flush so I kept tightening it. Tbh I wasn’t reefing on it I had a stubby ratchet and I wasn’t giving it much. But when it skipped (almost like the ratchet missed a tooth) I knew I was in trouble. Quote Link to comment Share on other sites More sharing options...
Mk1finks Posted March 13 Author Report Share Posted March 13 46 minutes ago, robido said: Try eurocarb I believe ive been talking with Robert. Not sure if he implied that I’m toast or if he had a solution. He did say the CS is discontinued which is what brought me here. Quote Link to comment Share on other sites More sharing options...
rotors7 Posted March 13 Report Share Posted March 13 (edited) I've got one ! I was keeping it as a spare but probably won't swap it back again. ? Edited March 13 by rotors7 Quote Link to comment Share on other sites More sharing options...
Mk1finks Posted March 14 Author Report Share Posted March 14 19 hours ago, rotors7 said: I've got one ! I was keeping it as a spare but probably won't swap it back again. ? Is it needing anything done to it? Im starting to think I’m carb-illiterate…. Quote Link to comment Share on other sites More sharing options...
rotors7 Posted March 14 Report Share Posted March 14 2 hours ago, Mk1finks said: Is it needing anything done to it? Im starting to think I’m carb-illiterate…. No, it's good to go, I swapped it for a Keihin out of curiosity. If you're interested, message me, I'll strip it and send some pictures. Quote Link to comment Share on other sites More sharing options...
