Mk1finks Posted March 12, 2024 Report Share Posted March 12, 2024 Hello, I am looking to purchase a PHBH26CS carburetor as I destroyed the threads that hold the bowl to the body on my 1997 montesa cota 315R Quote Link to comment Share on other sites More sharing options...
konrad Posted March 12, 2024 Report Share Posted March 12, 2024 So the body itself has a damaged thread? This part won't fix it? https://www.splatshop.co.uk/dellorto-float-bowl-nut.html If not, can you run a tap into the body and clean it up? Here's the entire carb with the BS suffix (your jetting may be different) https://www.splatshop.co.uk/dellorto-phbl-trials-carburettor.html Quote Link to comment Share on other sites More sharing options...
robido Posted March 13, 2024 Report Share Posted March 13, 2024 Try eurocarb Quote Link to comment Share on other sites More sharing options...
Mk1finks Posted March 13, 2024 Author Report Share Posted March 13, 2024 On 3/12/2024 at 11:53 PM, konrad said: So the body itself has a damaged thread? This part won't fix it? https://www.splatshop.co.uk/dellorto-float-bowl-nut.html If not, can you run a tap into the body and clean it up? Here's the entire carb with the BS suffix (your jetting may be different) https://www.splatshop.co.uk/dellorto-phbl-trials-carburettor.html Expand No, the bolt is fine, the body lost the first 3 rows of threads the bolt goes into. I didn’t have the pin that holds the float flapper seated enough and it held the bowl from seating but I didn’t notice. So it wasn’t sitting flush so I kept tightening it. Tbh I wasn’t reefing on it I had a stubby ratchet and I wasn’t giving it much. But when it skipped (almost like the ratchet missed a tooth) I knew I was in trouble. Quote Link to comment Share on other sites More sharing options...
Mk1finks Posted March 13, 2024 Author Report Share Posted March 13, 2024 On 3/13/2024 at 12:07 AM, robido said: Try eurocarb Expand I believe ive been talking with Robert. Not sure if he implied that I’m toast or if he had a solution. He did say the CS is discontinued which is what brought me here. Quote Link to comment Share on other sites More sharing options...
rotors7 Posted March 13, 2024 Report Share Posted March 13, 2024 (edited) I've got one ! I was keeping it as a spare but probably won't swap it back again. ? Edited March 13, 2024 by rotors7 Quote Link to comment Share on other sites More sharing options...
Mk1finks Posted March 14, 2024 Author Report Share Posted March 14, 2024 On 3/13/2024 at 8:03 AM, rotors7 said: I've got one ! I was keeping it as a spare but probably won't swap it back again. ? Expand Is it needing anything done to it? Im starting to think I’m carb-illiterate…. Quote Link to comment Share on other sites More sharing options...
rotors7 Posted March 14, 2024 Report Share Posted March 14, 2024 On 3/14/2024 at 3:14 AM, Mk1finks said: Is it needing anything done to it? Im starting to think I’m carb-illiterate…. Expand No, it's good to go, I swapped it for a Keihin out of curiosity. If you're interested, message me, I'll strip it and send some pictures. Quote Link to comment Share on other sites More sharing options...
